.. _yubikey-u2f: YubiKey\* Support ################# This tutorial explains how to configure a YubiKey\* for U2F authentication through a web browser on a |CL-ATTR| system. .. contents:: :local: :depth: 1 Description *********** YubiKey is a USB security token manufactured by `Yubico`_. Depending on the model, a YubiKey can support different authentication protocols including One-Time Password (OTP), Smart card, FIDO2, and Universal 2nd Factor (U2F). A list of `websites that accept U2F authentication with the YubiKey`_ is available on the Yubico website. See the Yubico website to learn more about the Yubikey: https://www.yubico.com/getstarted/ Prerequisites ************* This tutorial assumes you have: #. |CL| installed and running. #. Mozilla Firefox installed on |CL|. #. A YubiKey. Enable Linux udev rules for YubiKey *********************************** :command:`udev` is the Linux device manager that handles events when USB devices are added and removed. Custom rules needs to be created to properly identify the YubiKey and provide applications access. These instructions are derived from: `Yubico support article Using Your U2F YubiKey with Linux `_ #. Create the udev rules folder under :file:`/etc`. .. code:: bash sudo mkdir -p /etc/udev/rules.d/ #. Download the u2f rules from the Yubico GitHub: .. code:: bash curl -O https://raw.githubusercontent.com/Yubico/libu2f-host/master/70-u2f.rules #. Move the downloaded :file:`70-u2f.rules` file into the :file:`/etc/udev` folder. .. code:: bash sudo mv 70-u2f.rules /etc/udev/rules.d/ #. The udev rules should automatically be reloaded. However, they can be manually reloaded or you can reboot the system. .. code:: bash sudo udevadm control --reload-rules && sudo udevadm trigger #. Plugin and validate the YubiKey appears as a USB device. .. code:: bash lsusb Enable U2F in Mozilla Firefox ***************************** Firefox comes with U2F web authentication support disabled by default. U2F needs to be enabled in the advanced settings. These instructions are derived from: `Yubico support article Enabling U2F support in Mozilla Firefox `_ #. Launch Mozilla Firefox #. In the URL bar, type :command:`about:config` to access the advanced settings. .. code:: bash about:config #. Click the *I accept the risk!* button to continue to the advanced settings #. Search for the :command:`security.webauth.u2f` and double-click it so *Value* becomes **true**. Your YubiKey is now usable on |CL| with Mozilla Firefox with websites that support U2F authentication. Related topics ************** - |CL| :ref:`security` .. _`Yubico`: https://www.yubico.com/ .. _`websites that accept U2F authentication with the YubiKey`: .. https://www.yubico.com/works-with-yubikey/catalog/#protocol=universal-2nd-factor-(u2f)&usecase=all&key=all
