.. _machine-learning: TensorFlow\* machine learning ############################# This tutorial demonstrates the installation and execution of a TensorFlow\* machine learning example on |CL-ATTR|. It uses a Jupyter\* Notebook and MNIST data for handwriting recognition.  The initial steps show how to set up a Jupyter kernel and run a Notebook on a bare-metal |CL| system. .. contents:: :local: :depth: 1 Prerequisites ************* This tutorial assumes you have installed |CL| on your host system. For detailed instructions on installing |CL| on a bare metal system, follow the :ref:`bare metal installation tutorial`. Before you install any new packages, update |CL| with the following command: .. code-block:: bash sudo swupd update After your system is updated, add the following bundles to your system: * :command:`machine-learning-web-ui`: This bundle contains the Jupyter application. * :command:`machine-learning-basic`: This bundle contains TensorFlow and other useful tools. To install the bundles, run the following commands in your :file:`$HOME` directory: .. code-block:: bash sudo swupd bundle-add machine-learning-web-ui sudo swupd bundle-add machine-learning-basic Set up a Jupyter Notebook ************************* With all required packages and libraries installed, set up the file structure for the Jupyter Notebook. #. In the :file:`$HOME` directory, create a directory for the Jupyter Notebooks named :file:`Notebooks`. .. code-block:: bash mkdir Notebooks #. Within :file:`Notebooks`, create a directory named :file:`Handwriting`. .. code-block:: bash mkdir Notebooks/Handwriting #. Change to the new directory. .. code-block:: bash cd Notebooks/Handwriting #. Copy the :file:`MNIST_example.ipynb` file into the :file:`Handwriting` directory. .. note:: After installing the :command:`machine-learning basic` bundle, you can find the example code under :file:`/usr/share/doc/tensorflow/MNIST_example.ipynb`. The example code downloads and decompresses the MNIST data directly into the :file:`./mnist` directory. Alternatively, download the four files directly from the Yann LeCun’s `MNIST Database website`_ and save them into a :file:`mnist` directory within the :file:`Handwriting` directory. The files needed are: * `train-images-idx3-ubyte.gz`_: Training set images (9912422 bytes) * `train-labels-idx1-ubyte.gz`_: Training set labels (28881 bytes) * `t10k-images-idx3-ubyte.gz`_: Test set images (1648877 bytes) * `t10k-labels-idx1-ubyte.gz`_: Test set labels (4542 bytes) Run the Jupyter machine learning example code ********************************************* With |CL|, Jupyter, and TensorFlow installed and configured, you can run the example code. #. Go to the :file:`($HOME)/Notebooks` directory and start Jupyter with the following commands: .. code-block:: bash cd ~/Notebooks jupyter notebook The Jupyter server starts and opens a web browser showing the Jupyter file manager with a list of files in the current directory, as shown in Figure 1. .. figure:: /_figures/tensorflow/machine-learning-1.png :alt: Jupyter file manager Figure 1: The Jupyter file manager shows the list of available files. #. Click on the :file:`Handwriting` directory. The :file:`MNIST_example.ipynb` file created earlier should be listed there, as shown in Figure 2. .. figure:: /_figures/tensorflow/machine-learning-2.png :alt: Example file within the Jupyter file manager Figure 2: The example file within the Jupyter file manager. #. To run the handwriting example, click on the :file:`MNIST_example.ipynb` file to load the notebook, as shown in Figure 3. .. figure:: /_figures/tensorflow/machine-learning-3.png :alt: The loaded MNIST_example notebook Figure 3: The loaded MNIST_example notebook within the Jupyter file manager. #. Click the |run-cell| button to execute the code in the current cell and move to the next. #. Select the :guilabel:`In [2]` cell and click the |run-cell| button to load the MNIST data. The successful output is shown on Figure 4. .. figure:: /_figures/tensorflow/machine-learning-4.png :alt: Successful import of MNIST data Figure 4: Output after successfully importing the MNIST data. After the MNIST data is successfully downloaded and extracted into the :file:`mnist` directory within the :file:`($HOME)/Notebooks/Handwriting` directory, four .gz files are present and the four data sets are created: `trainX`, `trainY`, `testX` and `testY`. #. To inspect the imported data, the function in :guilabel:`In [3]` first instructs Jupyter to reshape the data into an array of 28 x 28 images and to plot the area in a 28 x 28 grid. Click the |run-cell| button twice to show the first two digits in the `trainX` dataset. An example is shown in Figure 5. .. figure:: /_figures/tensorflow/machine-learning-5.png :alt: Function to reshape data. Figure 5: A function reshapes the data and displays the first two digits in the `trainX` dataset. #. The :guilabel:`In [4]` cell defines the neural network. It provides the inputs, defines the hidden layers, runs the training model, and sets up the output layer, as shown in Figure 6. Click the |run-cell| button four times to perform these operations. .. figure:: /_figures/tensorflow/machine-learning-6.png :alt: Defining, building and training the neural network model Figure 6: Defining, building, and training the neural network model. #. To test the accuracy of the prediction that the system makes, select the :guilabel:`In [8]` cell and click the |run-cell| button. In this example, the number 6 was predicted with a 99% accuracy, as shown in Figure 7. .. figure:: /_figures/tensorflow/machine-learning-7.png :alt: Prediction example Figure 7: The system predicts a number providing the accuracy of the prediction. .. note:: To retest the accuracy of a random data point's prediction, run the cell :guilabel:`In [8]` again. It will take another random data point and predict its value. #. To check the accuracy for the whole dataset, select the :guilabel:`In [10]` cell and click the |run-cell| button. Our example's accuracy is calculated as 97.17%, as shown in Figure 8. .. figure:: /_figures/tensorflow/machine-learning-8.png :alt: System's accuracy Figure 8: The system's accuracy for the entire data set. For more in-depth information on the model used and the mathematics it entails, visit the TensorFlow tutorials `TensorFlow MNIST beginners demo`_ and `TensorFlow MNIST pros demo`_. **Congratulations!** You have successfully installed a Jupyter kernel on |CL|. In addition, you trained a neural network to successfully predict the values contained in a data set of hand-written number images. Related topics ************** * `MNIST Database website`_ * `TensorFlow MNIST beginners demo`_ * `TensorFlow MNIST pros demo`_ * `Jupyter main website`_ * `Jupyter documentation`_ * `MNIST at Wikipedia`_ .. _MNIST Database website: http://yann.lecun.com/exdb/mnist/ .. _train-images-idx3-ubyte.gz: http://yann.lecun.com/exdb/mnist/train-images-idx3-ubyte.gz .. _train-labels-idx1-ubyte.gz: http://yann.lecun.com/exdb/mnist/train-labels-idx1-ubyte.gz .. _t10k-images-idx3-ubyte.gz: http://yann.lecun.com/exdb/mnist/t10k-images-idx3-ubyte.gz .. _t10k-labels-idx1-ubyte.gz: http://yann.lecun.com/exdb/mnist/t10k-labels-idx1-ubyte.gz .. _Jupyter main website: http://jupyter.org/ .. _Jupyter documentation:  https://jupyter.readthedocs.io/en/latest/index.html .. _TensorFlow MNIST beginners demo: https://www.tensorflow.org/get_started/mnist/beginners .. _TensorFlow MNIST pros demo: https://www.tensorflow.org/get_started/mnist/pros .. _MNIST at Wikipedia: https://en.wikipedia.org/wiki/MNIST_database .. |run-cell| image:: /_figures/tensorflow/run-cell-button.png
