.. _smb-desktop: Samba\* as a client ################### This tutorial explains how to access an existing shared drive on Windows\* via Server Message Block (SMB) / Common Internet File System (CIFS) from the |CL| GNOME\* desktop. A CIFS filesystem is generally used to access shared storage locations, or share files. .. contents:: :local: :depth: 1 Prerequisites ************* * You have already `set up a shared location on Windows`_ Connect to Windows shared location with Nautilus ************************************************ #. From the desktop, select :guilabel:`Files` from the application menu. .. note:: GNOME Files is also known as `Nautilus`. #. In :guilabel:`Files`, select :guilabel:`Other Locations`. .. figure:: /_figures/samba/smb-desktop-1.png :scale: 100% :alt: Files, Other Locations Figure 1: Files, Other Locations #. In the lower taskbar, beside :guilabel:`Connect to Server`, enter the file-sharing address using the Windows sharing schema: .. code-block:: bash smb://servername/Share .. figure:: /_figures/samba/smb-desktop-2.png :scale: 100% :alt: Connect to Server Figure 2: Connect to Server #. Optional: If there are issues with DNS, you can use an IP address in place of the `servername` above. You must still specify the share. #. Optional: On the Windows machine, in a CLI, retrieve the IP address by entering the command: .. code-block:: bash ifconfig .. note:: If using the IP address, assure that it is accessible and secure. #. Select :guilabel:`Connect`. The server requests authentication, as shown in Figure 3. .. figure:: /_figures/samba/smb-desktop-3.png :scale: 100% :alt: Authentication Figure 3: Authentication #. Log in with the same Windows system credentials for which you granted access to the share. #. Select the appropriate checkbox to save your credentials. Consider carefully the security risks as a result of your selection. .. _set up a shared location on Windows: https://www.howtogeek.com/176471/how-to-share-files-between-windows-and-linux/
