.. _nvidia-cuda: NVIDIA\* CUDA Toolkit ##################### NVIDIA is a manufacturer of graphics processing units (GPU), also known as graphics cards. CUDA is a parallel computing platform and application programming interface model created by NVIDIA. It allows software developers and software engineers to use a CUDA-enabled graphics processing unit These instructions show how to install the CUDA Toolkit on |CL| after the :ref:`proprietary NVIDIA drivers ` have been installed. .. note:: Software installed outside of :ref:`swupd ` is not updated with |CL| updates and must be updated and maintained manually. .. contents:: :local: :depth: 2 Prerequisites ************* * A |CL| system with a `CUDA-Enabled NVIDIA device `_ * The :ref:`proprietary NVIDIA drivers ` have been installed. Compatibility ************* Check compatibility of NVIDIA components ======================================== To install the appropriate NVIDIA CUDA Toolkit version, it is important to understand the compute capability and compatible driver versions of your NVIDIA hardware. Information about NVIDIA compute capability, driver, and toolkit compatibility can be found at: https://developer.nvidia.com/cuda-gpus and https://docs.nvidia.com/deploy/cuda-compatibility/ Check GCC compatibility ======================= .. note:: This is only required for the development or compilation of CUDA applications. It is not required to run pre-built applications that have a dependency on CUDA. From the NVIDIA documentation: The CUDA development environment relies on tight integration with the host development environment, including the host compiler and C runtime libraries, and is therefore only supported on distribution versions that have been qualified for this CUDA Toolkit release. Refer to the `NVIDIA documentation on CUDA system requirements `_ for the latest kernel and compiler compatibility. For example, CUDA 10.2 on a system with the latest Linux kernel requires GCC8, which is older than the default GCC version for |CL|. Install the compatible version of GCC, if required: #. Install the :ref:`bundle ` with the appropriate GCC version. .. code:: bash sudo swupd bundle-add c-extras-gcc8 #. Create the directory :file:`/usr/local/cuda/bin`: .. code:: bash sudo mkdir -p /usr/local/cuda/bin #. Add symlinks to the older GCC version in the :file:`/usr/local/cuda/bin` directory. This will cause the older version of GCC to be used when :file:`/usr/local/cuda/bin` is in the $PATH environment variable. .. code:: bash sudo ln -s /usr/bin/gcc-8 /usr/local/cuda/bin/gcc sudo ln -s /usr/bin/g++-8 /usr/local/cuda/bin/g++ Downloading and Installation **************************** Download the NVIDIA CUDA Toolkit ================================ #. Go to the `NVIDIA CUDA downloads website`_ to get the latest CUDA Toolkit. If an older version of the CUDA Toolkit is required, go to the `CUDA Toolkit Archive `_. Choose the following settings and click *Download*. - Operating System: *Linux* - Architecture: *x86_64* - Distribution: *any* - Version: *any* - Installer Type: *runfile(local)* #. Open a terminal and navigate to where the :file:`cuda__linux.run` file was saved. In this example, it was saved in the Downloads folder. .. code-block:: bash cd ~/Downloads/ #. Make the :file:`cuda__linux.run` file executable: .. code-block:: bash chmod +x cuda__linux.run Install the NVIDIA CUDA Toolkit =============================== The NVIDIA CUDA installer will be directed to install files under :file:`/opt/cuda` as much as possible to keep its contents isolated from the rest of the |CL| files under :file:`/usr`. The CUDA installer automatically creates a symbolic link that allows the CUDA Toolkit to be accessed from :file:`/usr/local/cuda` regardless of where it was installed. #. Configure the dynamic linker to look for and cache shared libraries under :file:`/opt/cuda/lib64` where the NVIDIA installer will place libraries. .. code-block:: bash sudo mkdir -p /etc/ld.so.conf.d echo "include /etc/ld.so.conf.d/*.conf" | sudo tee --append /etc/ld.so.conf The CUDA installer will automatically create a file :file:`/etc/ld.so.conf.d/cuda-.conf` #. Navigate into the directory where the NVIDIA installer was downloaded: .. code-block:: bash cd ~/Downloads/ #. Run the installer with the advanced options below: .. code-block:: bash sudo ./cuda__linux.run \ --toolkit \ --installpath=/opt/cuda \ --no-man-page \ --override \ --silent #. Validate the CUDA Toolkit was installed by checking the NVIDIA CUDA compiler version: .. code-block:: bash /opt/cuda/bin/nvcc --version The CUDA Toolkit is now installed and can be used to compile and run CUDA applications. Using the NVIDIA CUDA Toolkit ***************************** #. Verify that the NVIDIA device characters files /dev/nvidia* exist and have the correct (0666) file permissions. The character devices should be automatically created on system with the NVIDIA driver loaded through X server, but will not be on systems that do not automatically load the NVIDIA driver. .. code:: ls -l /dev/nvidia* #. If your system does not have the NVIDIA character devices created automatically, run the `script from NVIDIA documentation `_ with root privileges. Alternatively a setuid utility, :command:`nvidia-modprobe`, can be compiled and installed to automatically create the device character files on-demand. .. code:: wget https://download.nvidia.com/XFree86/nvidia-modprobe/nvidia-modprobe-.tar.bz2 tar -xvf nvidia-modprobe-.tar.bz2 cd nvidia-modprobe-/ make sudo make install PREFIX=/usr/local/cuda/ #. When the CUDA toolkit is needed, export PATH variables pointing to the CUDA directories. This will temporarily add CUDA files to the PATH and use the specified linked version of GCC for the terminal session. .. code:: bash export PATH=/usr/local/cuda/bin:$PATH export LD_LIBRARY_PATH=/usr/local/cuda/lib64:$LD_LIBRARY_PATH Source code for CUDA sample located at :file:`/usr/local/cuda/NVIDIA_CUDA-_Samples`. See the `CUDA documentation on compiling samples `_ to learn more. Uninstalling ************ The NVIDIA drivers and associated software can be uninstalled and nouveau driver restored by: #. Run the :command:`sudo /usr/local/cuda/bin/cuda-uninstaller`. #. Follow the prompts on the screen and reboot the system. Debugging ********* * The NVIDIA CUDA installer places logs under :file:`/tmp/cuda-installer.log`. Additional resources ******************** * `NVIDIA CUDA Toolkit Documentation `_ * `Why aren't the NVIDIA Linux drivers open source? `_ * `Where can I get support for NVIDIA Linux drivers? `_ * `NVIDIA Accelerated Linux Graphics Driver Installation Guides `_ .. _`nouveau project`: https://nouveau.freedesktop.org/wiki/ .. _`NVIDIA CUDA downloads website`: https://developer.nvidia.com/cuda-downloads
