.. _kubernetes-bp: Kubernetes\* Best Practices ########################### This tutorial shows you how to manage your Kubernetes cluster while using :command:`swupd` to update |CL-ATTR|. .. contents:: :local: :depth: 1 Description *********** In our :ref:`kubernetes` tutorial, we explain how to set up a Kubernetes cluster on |CL| using `kubeadm`. `Kubeadm documentation`_ often builds on the assumption that the distribution uses a traditional package manager, such as RPM/DEB. However, |CL| uses `swupd` to update the OS, which in this case updates all of the kubernetes node and client binaries simultaneously, as part of the `cloud-native-basic` bundle (e.g., kubectl, kubeadm, kubelet). Running :command:`sudo swupd update` requires special care to ensure the OS incorporates the latest Kubernetes upgrades. This tutorial also describes the best practices for managing cluster upgrades with kubeadm on a |CL|-based cluster. Prerequisites ************* * Complete the :ref:`kubernetes` tutorial * Install the bundle `cloud-native-basic` .. note:: Other Linux\* distros shown in the Kubernetes upgrade documentation use the `apt-get update`, `apt-mark hold kubeadm`, and similar commands. These commands **are not valid** on |CL|. Update the control plane ************************ #. Read the kubernetes documentation `before you begin`_. #. On your master node, run the command: .. code-block:: bash sudo swupd update .. note:: If the minor version of Kubernetes changes, |CL| shows a message-of-the- day, or `motd`. When the motd appears, you **must postpone** a kubelet restart on master and nodes until the control plane is properly updated. :command:`swupd update` does not restart services automatically unless explicitly configured to do so. #. Now follow these instructions from the kubernetes documentation. * `Upgrade control plane`_ * `Drain control plane node`_ * `Restart Kubelet and undrain node`_ Update worker nodes ******************* #. On each worker node, run the command: .. code-block:: bash sudo swupd update #. Now follow these instructions from the kubernetes documentation: * `Drain node`_ * `Update kubelet configuration`_ * `Restart Kubelet and undrain node`_ .. _Kubeadm documentation: https://kubernetes.io/docs/reference/setup-tools/kubeadm/kubeadm-upgrade/ .. _Restart Kubelet and undrain node: https://kubernetes.io/docs/tasks/administer-cluster/kubeadm/kubeadm-upgrade-1-13/#restart-the-kubelet-for-all-nodes .. _Update kubelet configuration: https://kubernetes.io/docs/tasks/administer-cluster/kubeadm/kubeadm-upgrade-1-13/#upgrade-the-kubelet-config-on-worker-nodes .. _Drain node: https://kubernetes.io/docs/tasks/administer-cluster/kubeadm/kubeadm-upgrade-1-13/#drain-control-plane-and-worker-nodes .. _Restart kubelet and undrain node: https://kubernetes.io/docs/tasks/administer-cluster/kubeadm/kubeadm-upgrade-1-13/#restart-the-kubelet-for-all-nodes .. _Upgrade control plane: https://kubernetes.io/docs/tasks/administer-cluster/kubeadm/kubeadm-upgrade-1-13/#upgrade-the-control-plane-node .. _Drain control plane node: https://kubernetes.io/docs/tasks/administer-cluster/kubeadm/kubeadm-upgrade-1-13/#drain-control-plane-and-worker-nodes .. _Kubeadmn documentation: https://kubernetes.io/docs/reference/setup-tools/kubeadm/kubeadm/ .. _before you begin: https://kubernetes.io/docs/tasks/administer-cluster/kubeadm/kubeadm-upgrade-1-13/#before-you-begin
