.. _hadoop: Apache\* Hadoop\* ################# This tutorial explains the process of installing, configuring, and running Apache Hadoop on |CL-ATTR|. .. contents:: :local: :depth: 1 Description *********** For this tutorial, you will install Hadoop in a single machine running both the master and slave daemons. The Apache Hadoop software library is a framework for distributed processing of large data sets across clusters of computers using simple programming models. It is designed to scale up from single servers to thousands of machines, with each machine offering local computation and storage. Prerequisites ************* * :ref:`bare-metal-install-desktop` * In |CL|, run :command:`swupd update` Install Apache Hadoop ********************* Apache Hadoop is included in the :command:`big-data-basic` bundle. To install the framework, enter the following command: .. code-block:: bash sudo swupd bundle-add big-data-basic Configure Apache Hadoop *********************** #. To create the configuration directory, enter the following command: .. code-block:: bash sudo mkdir /etc/hadoop #. Copy the defaults from :file:`/usr/share/defaults/hadoop` to :file:`/etc/hadoop` with the following command: .. code-block:: bash $ sudo cp /usr/share/defaults/hadoop/* /etc/hadoop .. note:: Since |CL| is a stateless system, never modify the files under the :file:`/usr/share/defaults` directory. The software updater will overwrite those files. Once all the configuration files are in :file:`/etc/hadoop`, edit them to fit your needs. The `NameNode` server is the master server that manages the namespace of the files' system and regulates the clients' access to files. The first file to be edited, :file:`/etc/hadoop/core-site.xml`, informs the Hadoop daemon where `NameNode` is running. In this tutorial, `NameNode` runs in the `localhost`. #. Open the :file:`/etc/hadoop/core-site.xml` file using any editor and modify the file as follows: .. code-block:: xml fs.default.name hdfs://localhost:9000 #. Edit the :file:`/etc/hadoop/hdfs-site.xml` file. This file configures the :abbr:`HDFS (Hadoop Distributed File System)` daemons. This configuration includes the list of permitted and excluded data nodes and the size of those blocks. For this example, set the number of block replication to 1 from the default of 3 as follows: .. code-block:: xml :emphasize-lines: 6 dfs.replication 1 dfs.permission false #. Edit the :file:`/etc/hadoop/mapred-site.xml` file. This file configures all daemons related to `MapReduce`: `JobTracker` and `TaskTrackers`. With `MapReduce`, Hadoop can process big amounts of data in multiple systems. In our example, we set :abbr:`YARN (Yet Another Resource Manager)` as our runtime framework for executing `MapReduce` jobs as follows: .. code-block:: xml :emphasize-lines: 5,6 mapreduce.framework.name yarn #. Edit the :file:`/etc/hadoop/yarn-site.xml` file. This file configures all daemons related to `YARN`: `ResourceManager` and `NodeManager`. In our example, we implement the `mapreduce_shuffle` service, which is the default as follows: .. code-block:: xml :emphasize-lines: 4,5,8,9 yarn.nodemanager.aux-services mapreduce_shuffle yarn.nodemanager.auxservices.mapreduce.shuffle.class org.apache.hadoop.mapred.ShuffleHandler Configure your SSH key ********************** #. Create a SSH key. If you already have one, skip this step. .. code-block:: bash sudo ssh-keygen -t rsa #. Copy the key to your authorized keys. .. code-block:: bash sudo cat /root/.ssh/id_rsa.pub | sudo tee -a /root/.ssh/authorized_keys #. Log into the localhost. If no password prompt appears, you are ready to run the Hadoop daemons. .. code-block:: bash sudo ssh localhost Run the Hadoop daemons ********************** With all the configuration files properly edited, you are ready to start the daemons. When you format the `NameNode` server, it formats the metadata related to data nodes. Thus, all the information on the data nodes is lost and the nodes can be reused for new data. #. Format the `NameNode` server with the following command: .. code-block:: bash sudo hdfs namenode -format #. Start the DFS in `NameNode` and `DataNodes` with the following command: .. code-block:: bash sudo start-dfs.sh The console output should be similar to: .. code-block:: console Starting namenodes on [localhost] The authenticity of host 'localhost (::1)' can't be established. ECDSA key fingerprint is SHA256:97e+7TnomsS9W7GjFPjzY75HGBp+f1y6sA+ZFcOPIPU. Are you sure you want to continue connecting (yes/no)? #. Enter `yes` to continue. #. Start the `YARN` daemons `ResourceManager` and `NodeManager` with the following command: .. code-block:: bash sudo start-yarn.sh #. Ensure everything is running as expected with the following command: .. code-block:: bash sudo jps The console output should be similar to: .. code-block:: console 22674 DataNode 26228 Jps 22533 NameNode 23046 ResourceManager 22854 SecondaryNameNode 23150 NodeManager Run the MapReduce wordcount example *********************************** #. Create the input directory. .. code-block:: bash sudo hdfs dfs -mkdir -p /user/root/input #. Copy a file from the local file system to the HDFS. .. code-block:: bash sudo hdfs dfs -copyFromLocal local-file /user/root/input #. Run the `wordcount` example. .. code-block:: bash sudo hadoop jar /usr/share/hadoop/mapreduce/hadoop-mapreduce-examples-2.8.0.jar wordcount input output #. Read the output file "part-r-00000". This file contains the number of times each word appears in the file. .. code-block:: bash sudo hdfs dfs -cat /user/root/output/part-r-00000 **Congratulations!** You have successfully installed and setup a single node Hadoop cluster. Additionally, you ran a simple wordcount example. Your single node Hadoop cluster is up and running!
