.. _validate-signatures: Validate signatures ################### This guide describes how to validate the contents of a |CL-ATTR| image. .. contents:: :local: :depth: 1 Overview ******** Validating the contents of an image is a manual process and is the same process that :ref:`swupd-guide` performs internally. |CL| offers a way to validate the content of an image or an update. All validation of content works by creating and signing a hash. A valid signature creates a chain of trust. A broken chain of trust, seen as an invalid signature, means the content is not valid. .. _image-content-validation: Image content validation ************************ In the steps below, we used the installer image of the latest release of |CL|. You may use any image of |CL| you choose. #. Download the image, the signature of the SHA512 sum of the image, and the |CL| certificate used for signing the SHA512 sum. .. code-block:: console # Image curl -O https://cdn.download.clearlinux.org/current/clear-$(curl https://cdn.download.clearlinux.org/latest)-installer.img.xz # Signature of SHA512 sum of image curl -O https://cdn.download.clearlinux.org/current/clear-$(curl https://cdn.download.clearlinux.org/latest)-installer.img.xz-SHA512SUMS.sig # Certificate curl -O https://cdn.download.clearlinux.org/releases/$(curl https://cdn.download.clearlinux.org/latest)/clear/ClearLinuxRoot.pem #. Generate the SHA256 sum of the |CL| certificate. .. code-block:: console sha256sum ClearLinuxRoot.pem #. Ensure the generated SHA256 sum of the |CL| certificate matches the following SHA256 sum to verify the integrity of the certificate. .. code-block:: console 4b0ca67300727477913c331ff124928a98bcf2fb12c011a855f17cd73137a890 ClearLinuxRoot.pem #. Generate the SHA512 sum of the image and save it to a file. .. code-block:: console sha512sum clear-$(curl https://cdn.download.clearlinux.org/latest)-installer.img.xz > sha512sum.out #. Ensure the signature of the SHA512 sum of the image was created using the |CL| certificate. This confirms that the image is trusted and has not been modified. .. code-block:: console openssl smime -verify -purpose any -in clear-$(curl https://cdn.download.clearlinux.org/latest)-installer.img.xz-SHA512SUMS.sig -inform der -content sha512sum.out -CAfile ClearLinuxRoot.pem .. note:: The :command:`-purpose any` option is required when using OpenSSL 1.1. If you use an earlier version of OpenSSL, omit this option to perform signature validation. The :command:`openssl version` command may be used to determine the version of OpenSSL in use. #. The output should contain "Verification successful". If the output contains "bad_signature" anywhere, then the image is not trustworthy. Update content validation ************************* **swupd** validates all update content automatically before applying the update content. The process swupd follows internally is illustrated here with manual steps using the latest |CL| release. There is no need to perform these steps manually when performing a :command:`swupd update`. #. Download the :abbr:`MoM (top-level manifest)`, the signature of the MoM, and the Swupd certificate used for signing the signature of the MoM. .. code-block:: console # MoM curl -O https://cdn.download.clearlinux.org/update/$(curl https://cdn.download.clearlinux.org/latest)/Manifest.MoM # Signature of MoM curl -O https://cdn.download.clearlinux.org/update/$(curl https://cdn.download.clearlinux.org/latest)/Manifest.MoM.sig # Swupd certificate curl -O https://cdn.download.clearlinux.org/releases/$(curl https://cdn.download.clearlinux.org/latest)/clear/Swupd_Root.pem #. Generate the SHA256 sum of the swupd certificate. .. code-block:: console sha256sum Swupd_Root.pem #. Confirm that the generated SHA256 sum of the swupd certificate matches the SHA256 sum shown below to verify the integrity of the certificate. .. code-block:: console ff06fc76ec5148040acb4fcb2bc8105cc72f1963b55de0daf3a4ed664c6fe72c Swupd_Root.pem #. Confirm that the signature of the MoM was created using the Swupd certificate. This signature validates the update content is trustworthy and has not been modified. .. code-block:: console openssl smime -verify -purpose any -in Manifest.MoM.sig -inform der -content Manifest.MoM -CAfile Swupd_Root.pem .. note:: The :command:`-purpose any` option is required when using OpenSSL 1.1. If you use an earlier version of OpenSSL, omit this option to perform signature validation. The :command:`openssl version` command may be used to determine the version of OpenSSL in use. .. note:: The SHA512 sum of the MoM is not generated and then signed. Instead, the MoM is signed directly because it is small in size compared to an image of |CL|. #. The output should contain "Verification successful". If the output contains "bad_signature" anywhere, then the MoM cannot be trusted. Because the MoM contains a list of hashes for bundle manifests, if the MoM cannot be trusted, then the bundle content cannot be trusted.
