.. _resource-limits: Resource limits ############### Linux systems employ limiting or quota mechanisms to provide quality of service for system resources and contain rogue processes. These limits are layered at the system-level and user-level. If these limits need to be modified, it is useful to understand the different limit configurations. .. contents:: :local: :depth: 2 System-wide limits ================== Some global resource limits are implemented in the Linux kernel and are controllable with kernel parameters. For example, a global limit for the maximum number of open files is set with the *fs.file-max* parameter. This limit applies to all processes and users an cannot be exceeded other limit values. Checking limit ************** You can check a current value with :command:`sysctl -n `. For example: .. code:: bash sysctl -n fs.file-max This *fs.file-max* value is set intentionally high on |CL| systems by default. You can check the maximum value supported by the system with: .. code:: cat /proc/sys/fs/file-max Overriding limit **************** You can override a value with :command:`sysctl -w `. For example: .. code:: bash sudo sysctl -w fs.file-max= If needed permanently, the value can be set by creating a :file:`/etc/sysctl.d/*.conf` file (see :command:`man sysctl.d` for details). For example: .. code:: bash sudo mkdir -p /etc/sysctl.d/ sudo tee /etc/sysctl.d/fs-file-max.conf > /dev/null <<'EOF' fs.file-max= EOF Per-user limits =============== For processes not managed by systemd, resource limits can be set for PAM logins on a per-user basis with upper and lower limits in the :file:`/etc/security/limits.conf` file. You can set temporary values and check the current values with the :command:`ulimit` command. For example, to change the soft limit of maximum number of open file descriptors for the current user: .. code:: ulimit -S -n See :command:`man limits.conf` for details. Service limits ============== Resource limits for services started with systemd units do not follow normal user limits because the process is started in a separate `Linux control group (cgroup) `_ Linux cgroups associate related process groups and provide resource accounting. Resource limits for individual systemd services can be controlled inside their unit files or its configuration drop-in directory with the resource Limit directives. See `process properties section of the systemd.exec man page `_. Resource limits for all systemd services can be controlled with a file in the :file:`/etc/systemd/system.conf.d/` directory. For example, to have no restriction on the number of open files: .. code:: sudo mkdir -p /etc/systemd/system.conf.d/ sudo tee /etc/systemd/system.conf.d/50-nfiles.conf > /dev/null <<'EOF' [Manager] DefaultLimitNOFILE=infinity EOF
