.. _developer-workstation: Developer Workstation ##################### This guide helps you find the minimum set of bundles needed to start your |CL-ATTR| development project. Before continuing, review the :ref:`swupd ` guide to learn more about the swupd tool and how |CL| simplifies software versioning compared to other Linux\* distributions. .. contents:: :local: :depth: 1 Workstation Setup ***************** After installing the minimum set of bundles required to get started, you can add more bundles relevant to your specific use case. To run any process required for |CL| development, you can add the large bundle :ref:`*os-clr-on-clr* `. However, you may want to deploy a leaner OS with only bundles relevant to your project. Use the **Developer Profiles** tabs to start installing *suggested bundles* based on your role or project. Installing any ``dkms`` bundle gives all the tools you need to start. Consider these profiles as a starting point. .. tip:: Click on a bundle to learn how to install it using :command:`swupd`. .. tabs:: .. tab:: AI/ML Engineer .. list-table:: :widths: 50, 50 :header-rows: 1 * - Function - Bundle * - Build machine learning applications with a full suite of libraries. - `machine-learning-basic `_ * - Build machine learning applications with PyTorch, an optimized tensor library for deep learning. - `machine-learning-pytorch `_ * - Build machine learning applications using Tensorflow, a library for numerical computation using deep neural networks. - `machine-learning-tensorflow `_ * - Web-based, interactive tools for machine learning. - `machine-learning-web-ui `_ * - Machine learning Docker container. - `machine-learning `_ * - Pre-built Python libraries for Data Science. - `python-extras `_ * - API helper for cloud access. - `cloud-api `_ .. tab:: Computer Vision Engineer .. list-table:: :widths: 50, 50 :header-rows: 1 * - Function - Bundle * - Build computer vision applications. - `computer-vision-basic `_ * - Work with deep learning and edge-optimized models. - `computer-vision-models `_ * - API helper for cloud access. - `cloud-api `_ * - Run container applications from Dockerhub in lightweight virtual machines. - `containers-virt `_ * - All content for pkgconfig file opencv.pc. - `devpkg-opencv `_ * - *Refer also to Cloud Orchestration Engineer* - .. tab:: Cloud Orchestration Engineer .. list-table:: :widths: 50, 50 :header-rows: 1 * - Function - Bundle * - Contains Clear Linux\* OS native software for cloud. - `ethtool `_ * - Utilities for controlling TCP/IP networking and traffic control. - `iproute2 `_ * - API helper for cloud access. - `cloud-api `_ * - C++ runtime support. - `libstdcpp `_ * - Load and enumerate PKCS#11 modules. - `p11-kit `_ .. tab:: Kernel Developer .. list-table:: :widths: 50, 50 :header-rows: 1 * - Function - Bundle * - Installs kernel, initrd, kernel config, system map; creates a bootloader entry. - `kernel-install `_ * - Support module for building/loading via Dynamic Kernel Module System (DKMS) in LTS kernel. - `kernel-lts-dkms `_ * - Support module for building/loading via Dynamic Kernel Module System (DKMS) in native kernel. - `kernel-native-dkms `_ * - Support module for building/loading via Dynamic Kernel Module System (DKMS) in AWS kernel. - `kernel-aws-dkms `_ * - Run the Kernel-based Virtual Machine (KVM) with |CL| as a guest under KVM. - `kernel-kvm `_ * - Linux Test Project. - `ltp `_ .. tab:: Maker Developer .. list-table:: :widths: 50, 50 :header-rows: 1 * - Function - Bundle * - Basic tools for makers and experimenters. - `maker-basic `_ * - GIS/Mapping tools for makers. - `maker-gis `_ * - Electronic Design Tool. - `Fritzing `_ * - Open-source electronics prototyping platform. - `arduino-ide `_ .. tab:: System Administrator .. list-table:: :widths: 50, 50 :header-rows: 1 * - Function - Bundle * - Run popular terminal text editors. - `editors `_ * - Run network utilities and modify network settings. - `network-basic `_ * - Run a secure shell (SSH) server for access from remote machines. - `openssh-server `_ * - Run an HTTP server. - `nginx `_ * - Run an application server via HTTP. - `application-server `_ * - Run a SQLite database. - `sqlite `_ * - Bundle to automatically launch the GUI upon boot. - `desktop-autostart `_ swupd search ************ We recommend learning about :ref:`swupd `, to learn the commands to search for and add bundles relevant to your project. The guide provides an :ref:`example ` that shows you how to: * Use swupd to search for bundles * Use swupd to add bundles Core Concepts ************* We recommend that you understand these core concepts in |CL| *before* developing your project. * :ref:`Software update ` * :ref:`Mixer ` * :ref:`Autospec ` Related topics -------------- * `Developer Tooling Framework`_ for |CL| * `Bundle Definition Files`_ .. _Bundle Definition Files: https://github.com/clearlinux/clr-bundles .. _Developer Tooling Framework: https://github.com/clearlinux/common
