.. _deploy-at-scale: Deploy at Scale ############### This guide describes deployment considerations and strategies when deploying |CL-ATTR| at scale in your environment. .. contents:: :local: :depth: 1 Overview ******** In this guide the term *endpoint* refers to a system targeted for |CL| installation, whether that is a datacenter system or unit deployed in field. .. note:: This guide is not a replacement or blueprint for designing your own IT operating environment. Implementation details for a scale deployment are beyond the scope of this guide. Your |CL| deployment should complement your existing environment and available tools. It is assumed core IT dependencies of your environment, such as your network, are healthy and scaled to suit the deployment. Pick a usage and update strategy ******************************** Different business scenarios call for different deployment methodologies. |CL| offers the flexibility to continue consuming the upstream |CL| distribution or the option to fork away from the |CL| distribution and act as your own :abbr:`OSV (Operating System Vendor)`. Below is an overview of some considerations. Create your own Linux distribution (mix) ======================================== This approach forks away from the |CL| upstream and has you act as your own :abbr:`OSV (Operating System Vendor)` by leveraging the :ref:`mixer` process to create customized images based on |CL|. This is a level of responsibility that requires having more infrastructure and processes to adopt. In return, this approach *offers you a high degree of control and customization*. Consider: * Development systems that generate bundles and updates should have sufficient performance for the task and be separate from the swupd update webservers that serve update content to production machines. * swupd update webservers that serve update content to production machines should be appropriately scaled. Specific implementation details for a scalable, resilient web server are beyond the scope of this document. (See :ref:`mixer` for more information about update servers.) Adopt an agile methodology ========================== The cloud, and other scaled deployments, are all about flexibility and speed. It only makes sense that any |CL| deployment strategy should follow suit. Manually rebuilding your own bundles or mix for every release is not sustainable at a large scale. A |CL| deployment pipeline should be agile enough to validate and produce new versions with speed. Whether or not those updates actually make their way to your production can be separate business decision. However this *ability to frequently roll new versions* of software to your endpoints is an important prerequisite. You own the validation and lifecycle of the OS and should treat it like any other software development lifecycle. Below are some pointers: * Thoroughly understand the custom software packages that you will need to integrate with |CL| and maintain along with their dependencies. * Setup a path to production for building |CL| based images. At minimum this should include: * A development clr-on-clr environment to test building packages and bundles for |CL| systems. * A pre-production environment to deploy |CL| versions to before production * Employ a continuous integration and continuous deployment (CI/CD) philosophy in order to: - Automatically pull custom packages as they are updated from their upstream projects or vendors. - Generate |CL| bundles and potentially bootable images with your customizations, if any. - Measure against metrics and indicators which are relevant to your business (e.g. performance, power, etc) from release to release. - Integrate with your organization's governance processes, such as change control. Versioning infrastructure ========================= |CL| version numbers are very important as they apply to the whole infrastructure stack from OS components to libraries and applications. Good record keeping is important, so you should keep a detailed registry and history of previously deployed versions and their contents. With a glance at the |CL| version numbers deployed, you should be able to tell if your Clear systems are patched against a particular security vulnerability or incorporate a critical new feature. Pick an image distribution strategy *********************************** Once you have decided on a usage and update strategy, you should understand *how* |CL| will be deployed to your endpoints. In a large scale deployment, interactive installers should be avoided in favor of automated installations or prebuilt images. There are many well-known ways to install an operating system at scale. Each have their own benefits, and one may lend itself easier in your environment depending on the resources available to you. See the available :ref:`image-types`. Below are some common ways to install |CL| to systems at scale: Bare metal ========== Preboot Execution Environments (PXE) or other out-of-band booting options are one way to distribute |CL| to physical bare metal systems on a LAN. This option works well if your customizations are fairly small in size and infrastructure can be stateless. The |CL| `Downloads`_ page offers a live image that can be deployed as a PXE boot server if one doesn't already exist in your environment. Also see documentation on how to :ref:`bare-metal-install-server`. Cloud instances or virtual machines =================================== Image templates in the form of cloneable disks are an effective way to distribute |CL| for virtual machine environments, whether on-premises or hosted by a Cloud Solution Provider (CSP). When used in concert with cloud VM migration features, this can be a good option for allowing your applications a degree of high availability and workload mobility; VMs can be restarted on a cluster of hypervisor host or moved between datacenters transparently. The |CL| `Downloads`_ page offers example prebuilt VM images and is readily available on popular CSPs. Also see documentation on how to :ref:`virtual-machine-install`. Containers ========== Containerization platforms allow images to be pulled from a repository and deployed repeatedly as isolated containers. Containers with a |CL| image can be a good option to blueprint and ship your application, including all its dependencies, as an artifact while allowing you or your customers to dynamically orchestrate and scale applications. |CL| is capable of running a Docker host, has a container image which can be pulled from DockerHub, or can be built as a customized container. For more information visit the `Containers`_ page. Considerations with stateless systems ************************************* An important |CL| concept is statelessness and partitioning of system data from user data. This concept can change the way you think about an at scale deployment. Backup strategy =============== A |CL| system and its infrastructure should be considered a commodity and be easily reproducible. Avoid focusing on backing up the operating system itself or default values. Instead, focus on backing up what's important and unique - the application and data. In other words, only focus on backing up critical areas like :file:`/home`, :file:`/etc`, and :file:`/var`. Meaningful logging & telemetry ============================== Offload logging and telemetry from endpoints to external servers, so it is persistent and can be accessed on another server when an issue occurs. * Remote syslogging in |CL| is available through the `systemd-journal-remote.service`_ * |CL| offers a :ref:`telem-guide`, which can be a powerful tool for a large deployment to quickly crowdsource issues of interest. Take advantage of this feature with careful consideration of the target audience and the kind of data that would be valuable, and expose events appropriately. Like any web server, the telemetry server should be appropriately scaled and resilient. Specific implementation details for a scalable, resilient web server are beyond the scope of this document. Orchestration and configuration management ========================================== In cloud environments, where systems can be ephemeral, being able to configure and maintain generic instances is valuable. |CL| offers an efficient cloud-init style solution, `micro-config-drive`_, through the *os-cloudguest* bundles which allow you to configure many Day 1 tasks such as setting hostname, creating users, or placing SSH keys in an automated way at boot. For more information on automating configuration during deployment of |CL| endpoints see the :ref:`ipxe-install` guide. A configuration management tool is useful for maintaining consistent system and application-level configuration. Ansible\* is offered through the *sysadmin-hostmgmt* bundle as a configuration management and automation tool. Cloud-native applications ========================= An Infrastructure OS can design for good behavior, but it is ultimately up to applications to make agile design choices. Applications deployed on |CL| should aim to be host-aware but not depend on any specific host to run. References should be relative and dynamic when possible. The application architecture should incorporate an appropriate tolerance for infrastructure outages. Don't just keep stateless design as a noted feature. Continuously test its use; Automate its use by redeploying |CL| and application on new hosts. This naturally minimizes configuration drift, challenges your monitoring systems, and business continuity plans. .. _`Downloads`: https://clearlinux.org/downloads/ .. _`Containers`: https://clearlinux.org/downloads/containers .. _`systemd-journal-remote.service`: https://www.freedesktop.org/software/systemd/man/systemd-journal-remote.service.html .. _`micro-config-drive`: https://github.com/clearlinux/micro-config-drive .. |WEB-SERVER-SCALE| replace:: There are many well-known ways to achieve a scalable and resilient web server for this purpose, however implementation details are not in the scope of this document. In general, they should be close to your endpoints, highly available, and easy to scale with a load balancer when necessary.
