.. _container-image-modify: Modify a |CL|-based container image ################################### This guide describes how to customize |CL-ATTR|-based container `images on Docker Hub`_, which include popular applications and runtimes. .. contents:: :local: :depth: 1 Overview ******** Most of these images utilize a Docker build feature called a `multi-stage build to reduce image size`_ while some use single-stage build Dockerfiles. An official base `clearlinux image on Docker Hub`_ is also available. To create a generic |CL| container image, see :ref:`our guide `. Prerequisites ************* * Set up a functional Docker environment as described in :ref:`docker`. * Download the |CL| microservice Dockerfile repo with the following command: .. code-block:: bash git clone https://github.com/clearlinux/dockerfiles.git * Navigate to and operate from the cloned :file:`dockerfiles` directory. .. code-block:: bash cd dockerfiles/ Example 1: Add a bundle *********************** In this example, we add :command:`wget` to the **clearlinux/redis** Dockerfile. #. Enter :command:`swupd search wget` to discover which |CL| bundle includes the software. The output should tell you that :command:`wget` is available in the *wget* bundle. #. Open a an editor to modify the Dockerfile. .. code-block:: bash $EDITOR redis/Dockerfile #. Append the :command:`wget` bundle to the :command:`--bundles=` parameter of the :command:`swupd os-install` command. #. Run :command:`git diff`. The output shows the edits made after adding :command:`wget` in the clearlinux/redis Dockerfile. .. code-block:: diff diff --git a/redis/Dockerfile b/redis/Dockerfile index af977cb..b1effab 100644 --- a/redis/Dockerfile +++ b/redis/Dockerfile @@ -15,7 +15,7 @@ RUN source /os-release && \ mkdir /install_root \ && swupd os-install -V ${VERSION_ID} \ --path /install_root --statedir /swupd-state \ - --bundles=redis-native,findutils,su-exec --no-boot-update + --bundles=redis-native,findutils,su-exec,wget --no-boot-update #. Build the Dockerfile and apply a unique tag name. In this this example, we use :command:`wget_added` and add proxies. .. code-block:: bash docker build \ --no-cache \ --build-arg http_proxy=$http_proxy \ --build-arg https_proxy=$https_proxy \ --tag clearlinux/redis:wget_added \ redis/ #. Run the Dockerfile with the `wget --version` command to verify that :command:`wget` has been added to the image. .. code-block:: bash docker run clearlinux/redis:wget_added wget --version #. The output shows: .. code-block:: console GNU Wget 1.20.3 built on linux-gnu. -cares +digest -gpgme +https +ipv6 -iri +large-file -metalink +nls -ntlm +opie -psl +ssl/openssl Example 2: Change |CL| version (single-stage build) *************************************************** This example shows how to rebuild single-stage containers against a specific OS version, :file:``, by adding a new argument to the Docker build command line. #. Rebuild the :file:`clearlinux/machine-learning-ui`. Add an extra build argument :command:`swupd_args="-m "`; in this case, the build version is 31110. .. code-block:: bash :linenos: :emphasize-lines: 5 docker build \ --no-cache \ --build-arg http_proxy=$http_proxy \ --build-arg https_proxy=$https_proxy \ --build-arg swupd_args="-m 31110" \ --tag clearlinux/machine-learning-ui:31110 \ machine-learning-ui/ #. Run the docker container image: .. code-block:: bash docker run clearlinux/machine-learning-ui:31110 swupd info #. Sample output shows: .. code-block:: console Distribution: Clear Linux OS Installed version: 31110 Version URL: https://cdn.download.clearlinux.org/update Content URL: https://cdn.download.clearlinux.org/update Example 3: Change |CL| version (multi-stage build) ************************************************** This example shows how to rebuild the cgit Dockerfile to use a specific |CL| version. The clearlinux/cgit Dockerfile has a multi-stage build with multiple layers: *os-core*, *httpd*, and *cgit*. This can be used as reference for building other multi-stage images with any number of layers. .. important:: All upper layers of multi-stage Dockerfiles inherit the |CL| version from the base layer. Rebuild the all underlying base layers against the desired OS version. In this example, four base layers must be rebuilt. First layer: os-core -------------------- #. Rebuild the first layer, *os-core*. Add an extra build argument :command:`swupd_args="-m "`; in this case, the build version is 31110. .. code-block:: bash :linenos: :emphasize-lines: 5 docker build \ --no-cache \ --build-arg http_proxy=$http_proxy \ --build-arg https_proxy=$https_proxy \ --build-arg swupd_args="-m 31110" \ --tag clearlinux/os-core:31110 \ os-core/ #. Verify the version-specific image is available: .. code-block:: bash docker images clearlinux/os-core:31110 Second layer: httpd ------------------- The next layer is :file:`clearlinux/httpd`. #. Change the :file:`httpd/Dockerfile` to use the version-specific *os-core:31110* image that was previously built. .. code-block:: bash $EDITOR httpd/Dockerfile #. Run :command:`git diff`. The output shows a diff of a modified :file:`clearlinux/httpd` Dockerfile that uses the previously built clearlinux/os-core:31110. .. code-block:: diff diff --git a/httpd/Dockerfile b/httpd/Dockerfile index 6b2a6bf..9df89e4 100644 --- a/httpd/Dockerfile +++ b/httpd/Dockerfile @@ -7,7 +7,7 @@ RUN swupd update --no-boot-update $swupd_args # Grab os-release info from the minimal base image so # that the new content matches the exact OS version -COPY --from=clearlinux/os-core:latest /usr/lib/os-release / +COPY --from=clearlinux/os-core:31110 /usr/lib/os-release / # Install additional content in a target directory # using the os version from the minimal base @@ -26,7 +26,7 @@ COPY --from=clearlinux/os-core:latest / / os_core_install/ RUN cd / && \ find os_core_install | sed -e 's/os_core_install/install_root/' | xargs rm -d &> /dev/null || true -FROM clearlinux/os-core:latest +FROM clearlinux/os-core:31110 #. Build Dockerfile. .. code-block:: bash docker build \ --no-cache \ --build-arg http_proxy=$http_proxy \ --build-arg https_proxy=$https_proxy \ --tag clearlinux/httpd:31110 \ httpd/ Third layer: cgit ----------------- The next layer is :file:`clearlinux/cgit`. #. Change the :file:`cgit/Dockerfile` to use the desired OS version; in this case, the build version is 31110. .. code-block:: bash $EDITOR cgit/Dockerfile #. Run :command:`git diff`. The output shows: .. code-block:: diff diff --git a/cgit/Dockerfile b/cgit/Dockerfile index 9a3796d..59260fe 100644 --- a/cgit/Dockerfile +++ b/cgit/Dockerfile @@ -7,7 +7,7 @@ RUN swupd update --no-boot-update $swupd_args # Grab os-release info from the minimal base image so # that the new content matches the exact OS version -COPY --from=clearlinux/httpd:latest /usr/lib/os-release / +COPY --from=clearlinux/httpd:31110 /usr/lib/os-release / # Install additional content in a target directory # using the os version from the minimal base @@ -22,11 +22,11 @@ RUN source /os-release && \ # file exists on different layers. To minimize docker # image size, remove the overlapped files before copy. RUN mkdir /os_core_install -COPY --from=clearlinux/httpd:latest / /os_core_install/ +COPY --from=clearlinux/httpd:31110 / /os_core_install/ RUN cd / && \ find os_core_install | sed -e 's/os_core_install/install_root/' | xargs rm -d &> /dev/null || true -FROM clearlinux/httpd:latest +FROM clearlinux/httpd:31110 #. Build Dockerfile. .. code-block:: bash docker build \ --no-cache \ --build-arg http_proxy=$http_proxy \ --build-arg https_proxy=$https_proxy \ --tag clearlinux/cgit:31110 \ cgit/ #. Verify the installed OS version by noting the :command:`VERSION_ID` value in the :file:`/usr/lib/os-release` file in the container filesystem. .. code-block:: bash :linenos: :emphasize-lines: 6 docker run clearlinux/cgit:31110 cat /usr/lib/os-release NAME="Clear Linux OS" VERSION=1 ID=clear-linux-os ID_LIKE=clear-linux-os VERSION_ID=31110 PRETTY_NAME="Clear Linux OS" ANSI_COLOR="1;35" HOME_URL="https://clearlinux.org" SUPPORT_URL="https://clearlinux.org" BUG_REPORT_URL="mailto:dev@lists.clearlinux.org" PRIVACY_POLICY_URL=http://www.intel.com/privacy Example 4: Customize an application image at runtime **************************************************** This section describes how to modify a published |CL| container at runtime. In this example, we add Tensorflow\* into a :command:`clearlinux/python` container. This approach can help accelerate the feature development process. In this example, three separate console windows are used to easily interact inside and outside of the container. First console: Start the container ---------------------------------- #. Launch the clearlinux/python container. .. code-block:: bash docker run -it --rm clearlinux/python Python 3.7.3 (default, Jun 17 2019, 00:47:04) [GCC 9.1.1 20190616 gcc-9-branch@272336] on linux Type "help", "copyright", "credits" or "license" for more information. #. Try to import Tensorflow inside the container using the command: :command:`import tensorflow as tf`. The example below shows the expected error message because the Docker image does not yet include the Tensorflow module. .. code-block:: bash >>> import tensorflow as tf Traceback (most recent call last): File "", line 1, in ModuleNotFoundError: No module named 'tensorflow' >>> Second console: Add a bundle ---------------------------- #. In another console, find the :command:`` of clearlinux/python launched. This example Container ID is d4ce9d526fa6. .. code-block:: bash docker ps #. The output shows: .. code-block:: console CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES d4ce9d526fa6 clearlinux/python python3 About a minute ago Up About a minute amazing_villani #. Connect to the running clearlinux/python container. .. code-block:: bash docker exec -it d4ce9d526fa6 /usr/bin/bash root@d4ce9d526fa6/ # #. Use :command:`swupd` to install the machine-learning-tensorflow bundle. .. code-block:: bash root@d4ce9d526fa6/ # swupd bundle-add machine-learning-tensorflow Loading required manifests... Downloading packs (692.32 Mb) for: - machine-learning-tensorflow … … ...100% Finishing packs extraction... No extra files need to be downloaded Installing bundle(s) files... ...100% Calling post-update helper scripts. Successfully installed 1 bundle #. After the machine-learning-tensorflow bundle is installed in the container, in the first console, import Tensorflow, which will be successful now. You could also save the updated container using the command :command:`docker commit `. .. code-block:: bash >>> import tensorflow as tf >>> tf.__version__ '1.13.1' Third console: Save the modified container ------------------------------------------ #. In a third console, save the container with a new tag. Our example uses the tag `tensorflow_added` to identify our modified container. .. code-block:: bash docker commit d4ce9d526fa6 clearlinux/python:tensorflow_added #. Launch the modified container, and then import Tensorflow with success. .. code-block:: bash docker run -it clearlinux/python:tensorflow_added Python 3.7.3 (default, Jun 17 2019, 00:47:04) [GCC 9.1.1 20190616 gcc-9-branch@272336] on linux Type "help", "copyright", "credits" or "license" for more information. .. code-block:: bash >>> import tensorflow as tf >>> tf.__version__ '1.13.1' >>> Background ********** Multi-stage Dockerfiles contain more than one :command:`FROM` directive. All of the multi-stage Clear Linux OS Dockerfiles share a common base layer called :command:`clearlinux/os-core:latest`. All of the higher level layers inherit the Clear Linux OS version from this base layer. For details on how we leveraged multi-stage Docker builds, see the article `Minimizing Clear Linux OS container sizes`_. #. :command:`clearlinux/os-core` is built once per day. It is a container containing a minimal Linux userspace. #. The target container image uses either :command:`clearlinux/os-core` as a base layer or another container image :command:`clearlinux/` as a base layer. #. Bundle(s) containing the application are downloaded during the first stage of the build process using :command:`swupd`. #. The final container image is a composition of its base layer and the specific feature layer, via :command:`FROM clearlinux/:latest , such as: os-core, httpd, and via :command:`COPY --from=builder / install_root /`. Using this method, the target container images are kept up to date without file duplication. For application-centric containers, `os-core-update` is excluded to improve size optimization. Related topics ************** * :ref:`docker` * :ref:`container-image-new` .. _images on Docker Hub: https://hub.docker.com/u/clearlinux .. _GitHub\*: https://github.com/clearlinux/dockerfiles .. _clearlinux image on Docker Hub: https://hub.docker.com/_/clearlinux .. _clearlinux microservice dockerfile repo: https://github.com/clearlinux/dockerfiles .. _multi-stage build: https://docs.docker.com/develop/develop-images/multistage-build/ .. _Minimizing Clear Linux OS container sizes: https://clearlinux.org/blogs-news/minimizing-clear-linux-os-container-sizes .. _multi-stage build to reduce image size: https://clearlinux.org/blogs-news/minimizing-clear-linux-os-container-sizes
