.. _enable-huge-pages: Configure Huge Pages ######################## In |CL| hugepages are enabled by default. The default hugepage size is 2MB. The total number of hugepages is set to 0 by default. This guide shows you how to add hugepages to the system and how to change the default hugepage size. #. To check the enabled state, run the following command. .. code-block:: bash cat /sys/kernel/mm/transparent_hugepage/enabled The output will look like .. code-block:: console [always] madvise never .. note:: The active option is enclosed in brackets. In this case, always is active, which means hugepages are enabled for every process. The `madvise` option means that hugepages are enabled for processes that explicitly call `madvise`_. #. To check the size of hugepages, run the below command. .. code-block:: bash cat /proc/meminfo | grep Huge The output should look similar to the following. Although hugepages is enabled, there are no hugepages available to allocate. .. code-block:: console AnonHugePages: 624640 kB ShmemHugePages: 0 kB FileHugePages: 0 kB HugePages_Total: 0 HugePages_Free: 0 HugePages_Rsvd: 0 HugePages_Surp: 0 Hugepagesize: 2048 kB Hugetlb: 0 kB #. If you need 1GB (1,048,576 bytes) of hugepages enabled, then `HugePages_Total` should be set to 512. Enable it temporarily using the following. .. code-block:: bash echo 512 | sudo tee /sys/kernel/mm/hugepages/hugepages-2048kB/nr_hugepages To view the change, run the command in the previous setp again. #. Changing hugepages from the default 2MB to 1GB must be done at system boot through kernel boot parameters. In this example, we configure the size and number of allocatable huge pages at boot. .. code-block:: bash sudo mkdir -p /etc/kernel/cmdline.d cat << EOF | sudo tee -a /etc/kernel/cmdline.d/hugepages.conf default_hugepagesz=1G hugepagesz=1G hugepages=10 EOF sudo clr-boot-manager update sudo reboot .. _madvise: https://linux.die.net/man/2/madvise
